I have been noticing a noise on my 2019 Cherokee when vehicle is moving at higher speed (30+) and I let off the gas pedal and then press it again. It is difficult to describe, but probably best described as a click. There are not any performance issues, it only occurs at higher speeds, and cannot be replicated while stopped. Anyone know what I am referring to? I do not recall hearing it on test drives or when we first bought the Cherokee, but perhaps I was not paying attention. Sounds like it is coming from driver's side, but cannot tell if inside or outside.
I came across Wrangler owners discussing same thing, but did not read enough to see if there was a conclusion as to cause. The slightest noise bugs me--I did not buy an Infiniti one time because it had a barely audible but high pitched sound whenever the gas pedal was in a depressed position.
