I decide to go with a Redarc Tow-Pro Liberty brake controller on my '22 TH, as I really didn't want to hang a controller visible under the dash. This solution did require me to drill into my practically new Cherokee dashboard though, which I wasn't completely excited about either (lol) but it was the lesser evil. So, here's how it looks:
I had to find a good spot for the controller dial, somewhere easy reach as well as room behind the panel for the unit as well as looking not too dorky. I wanted to put it just to the right of the start button, but I found out there were obstructions behind that panel & it would have been really hard to clear that out of the way. So I mounted it a few inches below & to the left of the hvac panel.
First to drill the holes. 2 holes 7.5mm apart. Best way is to draw 2 dots onto paper tape the proper distance apart & use that as a template.
Next, drill away! First drill both holes with a smaller 1/8" bit, then enlarge the lower hole with a bigger 3/8" bit. Scary drilling into a visible part of my car! But, so far so good
Now to install the control button. The Redarc system button is nice & small, I hope I get used to seeing it there.
According to the instructions, the main controller box has to be FIRMLY mounted so it can't move around. You can't just stuff it loosely behind the dash. It can be mounted in any position though, and I found a great spot for it right behind the radio unit. I used heavy double sided tape as well as a tie wrap to make sure it doesn't move. Fortunately the controller cable (TPH-001) is just long enough to reach that spot.
Things are working out! All that's left to do is button the dash back up & test the unit out
I haven't tried pulling my camper with it yet but I did connect the trailer harness & the brakes did activate. The controller button has a multi-color light that indicates what it is doing. Our current camper is only around 2000 lbs, so not much of a challenge for this brake controller, but we are contemplating upgrading to a bigger/heavier camper soon. Good to know my Cherokee is ready for the task! If anyone has questions ask away
