2015 3.6L V6 Overland @ 103,000 miles
Began hearing a slight ticking noise under the hood for a month or so. Today had the P0304 (cylinder 4 misfire) error code. From what I can read, it looks like this is common on theses engines and is often times the rocker arms getting worn out (starting around 70,000ish miles) thus causing the camshaft(s) to get worn and cause an engine misfire. Has anyone else run into this issue? I plan on replacing all rocker arms and any camshafts that need to be replaced myself. But, I don't want to replace them with rocker arms that will do this again in the future. What rocker arms did you use? Should I call the dealership and get the rocker arms from them that they would recommend?
