Hello everyone, new member here with a strange problem.
2014 Cherokee TH 3.2. 70k miles. It has a 2" MFC lift, 265/70r17 tires. New PTU in August of 2021, installed at the dealer.
This morning while driving on ice, I noticed the rear wheels didn't assist at all. I gave it a bit of acceleration and it only spun the front wheels. I stopped, turned it off and back on and the problem remained. I then attempted a shift into low range. It worked and the jeep was indeed in low range but only in fwd.
Here's where it gets weird. If I lock the rear differential, the 4WD works. All the wheels are getting power as they should. If I unlock it, only the fronts work. I'm thinking one of the stub shafts inside the differential case actually broke and this is the only reason the differential works in locked mode.
I get no messages on the dash or any indication that there is a problem.
Can we agree that this is an RDM issue?
