Here is a little mod I recently did to keep my radiator free of bugs and debris. Did something similar on my Jeep Patriot and worked for 7 years !
The air flow is not impacted, or at least no more than the radiator filling with bugs, debris and becoming damaged by small stones. As it sits behind the grill it is almost invisible unless the hood is opened. With aluminum screen there is no worry about it being affected by heat from the radiator.
- I bought some aluminum screen from the hardware store
- Cut out a piece 24"x36" and folded over about 1" around all four sides to add strength/reinforce it
- Drilled some very small holes in the plastic trim to allow it to be fasten by way of zip ties (at the very bottom I simply used the existing plastic grill and wrapped the ties around that)
- It can be quickly removed simply by cutting the ties and pulling up and out
