Ice on Windshield
13K views 35 replies 19 participants last post by  Jaro360
#1 ·
We were driving back to central Texas from Santa Fe and ran into a winter storm. We experienced very low temps (3 degrees) and snow which built up ice on the windshield. I had to crank up the temp to hi and engage the defroster to keep the ice off the windshield. If I reduced the temp, the ice came back. It made it uncomfortably hot in the interior and I resorted to setting the temp on the passenger side to 65 and the driver side to hi. That made it bearable, but let some ice form on the passenger side windshield. We couldn't find any combination that kept the windshield clear and a comfortable temp inside the vehicle.
The roads were icy and the front wheel drive was great. We passed at least 25 wrecks between Sweetwater and Abilene and got stuck behind some vehicles that couldn't make it up some hills. The Jeep performed flawlessly in those conditions.
#2 ·
I have to agree that the windshield clearing of both fog on the inside and snow/ice on the outside is lacking for such a seemingly well designed vehicle. I have had the same situation as you with ice on the windshield but did find that on high defrost it would keep it clear. Didn't cook myself out of the vehicle yet though...
#6 ·
We drove through a winter storm for several hours the other day with our rental Sport model in the mountains of Colorado with the temperatures varying from zero to minus 10 fahrenheit. Toecutter is correct...what works best is AC on and recirc off. To keep ice from forming on the windshield, we had to crank up the heat and fan all the way, and send all the air to the windshield to keep the windshield as warm as possible. But it did make the interior unbearably hot after a while, so we opened the front passenger windows about an inch to get rid of some of the heat. Worked reasonably well considering the severe conditions. I also needed to keep turning on the rear window defogger as it "times out". I needed to keep the rear glass heated. If I did not, the rear wiper was useless.
#8 ·
You can ask the A/C compressor to come on all you want, but the fact is at 32F/0C, the compressor will not engage. Also any time defrost or defrost/floor heat is chosen, the system automatically de-faults to fresh air. For the conditions the OP was describing, I don't think there was really a problem, as I think any vehicle in those conditions would have had a problem keeping the windshield clear.
#9 ·
.... Also any time defrost or defrost/floor heat is chosen, the system automatically de-faults to fresh air. ....
Thanks for dropping these little tidbits that are often not in the owners manual!:smile:
Reactions: jamie1
#10 ·
i agree the defrost system in my TH sucks.
Even at what I would call warmer temps it has to be on full and like many are saying gets the cab very, very warm.
My diesel once warmed up on the highway keeps the windows clear better than the TH.
On the side it is -39C without a windchill here this morning and supposed to be this way for the rest of the week.
#13 ·
Are there any owners from Winterpeg that could chime in? From my memories there it was usually around -30C, so if they don't have problems, they may be doing something properly or differently.
#18 ·
Where I live is a lot colder than Winnipeg. I am about 6 hours north of Edmonton. I do have a problem with keeping all of the windows clear in the winter on my TH. Just hauled water with my Diesel for about 3 hours and the windows all stayed clear. It is near -40 here today. The TH today would be very frosty on the windows, especially the side ones.
#21 ·
Hit the defrost button with the A/C on, recirc off, and if it gets too hot then turn down the temperature setting.
On Wednesday night I drove home from the airport with the thermometer reading -1F. Defroster with A/C on, recirc off, and set the temp to 67F. It worked great and was a comfortable cabin temp.
Reactions: zzjdzz and al7fi
#22 ·
I have to super heat my windshield as well. I just crack a window or two and let the vent shades keep the weather out.
Reactions: zzjdzz
#24 ·
3 degrees?! I wish it were 3 degrees here! Its been -35 here for the past few days, with a wind chill of -47.
I haven't had any problems with my windows icing/fogging up. I usually keep it set to blow air at the window and the floor, and I adjust the temperature to my comfort.
#26 ·
I think the key is that you need dry air blowing across the glass to remove moisture. It doesn't necessarily need to be scorching hot. If the cabin feels too hot then you can turn down the temperature setting and increase the blower fan speed. I'm getting repetitive, but to get dry air you need the A/C on and the recirc off.
#28 ·
Cold air can contain less water vapour the colder it is.
Hot air can contain more water vapour the warmer it is.
You won't fully saturate dry air by blowing it once over your frosted windshield, etc. But you will remove more with dry air.
So yes, you are correct. Hotter air will melt ice. Drier air will defrost or defog more quickly.
#32 ·
Other things I thought of since my last post:
Any excess moisture inside the cabin (e.g., snow or standing water on your floormats, several sweaty passengers after a day of skiing) will make fogging more of a problem.
If you park inside a garage and there is snow or water inside your vehicle, then leave the windows and rear hatch open all night so moisture can exit the cabin.
#33 ·
Glad I came across this thread. Didn't know if it was unique to me, but I have more issues with defrost with this jeep than ever with any other vehicle. Thought it was pretty embarrassing the way it struggles to clear interior fog and/or exterior ice. Will try out AC to see if that helps.
#35 ·
No. My TH performs poorly compared to previous vehicles as far as windshield icing is concerned. Haven't had a problem with clearing windshield fog though . . .
Reactions: UN4GTBL
#36 ·
When on my last trip to Colorado from Arkansas I saw temperatures across Kansas as low as -8. I only had one issue with ice on the front windshield and that was after skiing with the temperature at -4 the next morning. The moisture in the floorboards was frozen and the warmer the interior got the more moist it got, no way I was rolling down any windows. I kicked the hawk over to manual and set it to the front defrost with the AC on. I have the cold weather package which warmed my windshield up about 2 inches from the bottom almost instantly clearing ice and snow, the rest soon followed. The rear glass also cleared very quickly but I had to engage the button several times due to the time out feature. The side mirrors also cleared themselves quickly. The cold weather package was well worth the investment. My feet were in boots with wool socks so I guess I've never noticed the lack of circulation that is complained about in the floorboard heat setting. Being from Arkansas, my only mistake on the trip was not having the "good" antifreeze windshield treatment in the tank, it was frozen any time temps got below 15.
