So today my 2015 Cherokee caught on fire. I had the recall performed yet it seems the hatch module decided to go up in flames. I’m not too happy.
ggWhat recall?So today my 2015 Cherokee caught on fire. I had the recall performed yet it seems the hatch module decided to go up in flames. I’m not too happy.
What exactly caught on fire??
Oh.. I just searched this and saw recalls from 2014-16 models for this issue.
I see that the liftgate control module is not on the hatch door, but in the area you showed.
I also see that there was a redesign after the original recall with a new part to completely seal the unit.
Was that second recall done on your vehicle?
Yes the speakers were installed several years ago just fine. The recall is to address this exact issue. I’ve had every recall done. It was the Hatch module mentioned in the recall that caught on fire. My lift stopped working so I checked the fuse and it was blown. I replaced the fuse, opened the hatch (worked fine) then it started smoking and flames started coming out from under the spare tire cover.Well this is new. Possibly the Aftermarket Alpine Setup install is the problem?
The fuse panel and BCM are supposed to protect the vehicle from serious problems.
Was the Aftermarket Alpine Setup properly installed?
The speakers are irrelevant here, there are no speakers in the hatch. No sub. Nothing. This is clearly a Jeep design flaw.
