How many pistons are in the front brakes on a 2014 Jeep Cherokee latitude V6 4x4
Just did some searching and something bugs me : I ran my VIN via your link (thanks, it shows more than the build sheet links I had), and for mine it says BRG too. No mention of HD brakes, and I have factory Tow Group (AD1 V6). It's strange because I went looking at brakes on the Autozone site, and they show 'Duralast' pads where they have fronts for BRF code, then some for BRG code while adding 'for non HD brakes' and lastly they show more, for HD brakes and no mention of BRG. Scrolling down further, they list some Brembo pads : some BRG and some for BRF with a mention 'Except Heavy Duty Brakes'. That tells me the Brembo pads for BRG are also a fit for HD front brakes, yet Duralast pads come in HD and non HD form, and they specify also that the HD pad kits come with pad spreader springs, while 'just BRG' do not.hI @jj03261989 ,
1. Go to this website and enter your VIN number: VIN decoder & lookup - Vindecoderz (note, I've found it only works on Chrome)
2. Scroll down to "Build Sheet". The 3 digit codes are Jeep's way of determining what components your Cherokee has. For brakes, BRG, means the dual-piston front brakes.
3. On my 2014 Trailhawk for example, I have brake code: "BRG: Anti-Lock 4-Wheel-Disc Brakes" The BRG code are the heavy duty 2 piston front brakes. I believe the other code, BRF, are the standard front brakes (1 piston). If your code has BRG, these brakes will work (2 piston front caliper).
Thanks guys.Just did some searching and something bugs me : I ran my VIN via your link (thanks, it shows more than the build sheet links I had), and for mine it says BRG too. No mention of HD brakes, and I have factory Tow Group (AD1 V6). It's strange because I went looking at brakes on the Autozone site, and they show 'Duralast' pads where they have fronts for BRF code, then some for BRG code while adding 'for non HD brakes' and lastly they show more, for HD brakes and no mention of BRG. Scrolling down further, they list some Brembo pads : some BRG and some for BRF with a mention 'Except Heavy Duty Brakes'. That tells me the Brembo pads for BRG are also a fit for HD front brakes, yet Duralast pads come in HD and non HD form, and they specify also that the HD pad kits come with pad spreader springs, while 'just BRG' do not.
I've seen similar offerings on Rock Auto. They sell kits from a bunch of manufacturers, and some differentiate between HD and non HD (BRG) pads while others don't.
So do I have HD brakes or not ? I think so, haha.. Since I didn't do my fronts the first time, I don't know if my original pads had the spreader spring on them, or not.
Edit to add (to the confusion) : not all HD compatible front pads come with spreader springs : some manufacturers have them, others don't...
Yup, definitely no 3.9l engine available!!! LoL!I wanted to check mine since I'll be coming up on brake service soon. LOL, that site doesn't list any real build information for mine, and the info it does list is questionable. A 3.9L 125 HP engine???
re: Then I get my free car wash and pig out on the snacks.Initially I got my Build sheet from my Jeep sales person.
Get a free CarFax report, mine is huge.
Get a VIP report from a Service Advisor and check on Open Recalls and TSB's.
Bought my Jeep from them and spend lots of money on repairs.
Nothing ventured, nothing gained. Somebody said that.
Thanks @AZJeeper . Yes, I've found the same - lots of sites that list the component items but the VINDECODERZ.com was the only one that included the actual 3 digit code which is key. @Mark_ just reported it still works for him so maybe there's some secret-sauce to getting a free full build sheet. 😎I just went to that site and my VIN doesn't show the Build Sheet but it had a fair amount of other information. By selecting a model (any model), the most recently searched VINs are on the right. I picked a random VIN that ended up being a 2020 Ford Fusion and it had the Build Sheet. Then I picked another that was a 2023 Land Rover Range Rover and it had nada other than the VIN! So that site is really hit-and-miss.
There are other places to get your build sheet, but I haven't found any with the sales codes. Here is a site that will get you the sanitized version of the build sheet.
Unfortunately, it doesn't give much info on brakes.
The only way I know to get that is through the dealer. Last time I checked they'll do it for free. ...but last time I checked was several years ago.
I went back myself, decided to go rotors and pads for a 2015 V6. Except for 2 manufacturers, all are offering the same front rotors for BRG and HD brakes.I went to RockAuto.com and looked up the calipers for a 2014 v6. There were no Mopar part numbers, but here are some clues.
P/N 1: Front; Brake Code BRG or BR6
P/N 2: Fits Front; Heavy Duty Brakes or Front; Standard Brakes; Brake Code BRG
P/N 3: Front; Standard Brakes; Brake Code BRF
The 2014 Cherokee Specifications sheet lists the following:
Mopar part numbers (not listed on RockAuto) are 68225168AD for the single piston right, and 68212010AA for dual piston right. Left are usually one digit difference. The
applicable vehicles for the single piston and duel piston look identical for the 2014 model, so little help there.
So deductive reasoning would be
Elementary, my dear Watson.
- BRG = BR6.
- Standard Brakes = BRG or BRF.
- BRG can be Heavy Duty or Standard (depending on model one would think).
- As others had confirmed, Heavy Duty brakes are dual piston.
- Therefore BRG/BR6 are dual piston, Mopar P/N 68212010AA for the right side.
- BRF is single piston, Mopar P/N 68225168AD for the right side.
- If you have two humps on your caliper, you have the dual piston. There is only one P/N for the dual piston (per side).
