41 - 43 of 43 Posts
i just used a digital torque wrench to figure out what torque was used to tighten the drain plug in case anyone is anal. it 80 Nm or 60 Ft/lbs. and as for the filter cap, on mine its printed on as 25.5 Nm or ~19 ft/lbs
now; that was after i took it to the dealership for the oil change to be done by them. whether or not this is what the manufacturer wants that is another thing.
Im really hoping someone can confirm these values
Huh ?
60 ft-lbs is for lug nuts on a small car. Way too tight for an oil drain plug. Checking around for numbers, oil drain plugs (on cars/light trucks/SUVs) are usually specced between 20 and 30 ft-lbs, no more.
As for the filter cap, it can't be that tight, and is probably done in the in-lbs range, not ft-lbs...
How did you check this ? By checking torque in reverse when the bolt/cap releases ? If so, that is not the way to do it... because a tighened fastener will not "release" at the same torque value it was tighened to. More torque is needed to release, because of friction, sometimes much more.
Best way to check for the filter cap : use a paint pen or tire chalk and mark the cover to the housing with a line. Next, if you really want to know the torque, just remove unscrew the cap a bit, then use a torque wrench (in-lbs) to tighen to the painted line. Edit to add : this can only be done on an initially properly torqued cap though...
For the oil drain plug torque spec, best to refer to a shop manual (or look online).
Oh and welcome to the forum ;)
41 - 43 of 43 Posts
