Hey, new member here trying to figure out why my Jeep tried to leave me stranded on the beach.
2020 trailhawk
Drove about 3 miles on the beach (Assateague Island, so alot of tracks to follow, not extremely soft) when the prompt "Service Electronic Stability Control System" came up immediately followed by "4wd system temperarily unavailble". I was in "Sand/Mud" mode. Tried shutting it off and restarting but would not clear that error. Made it out in 2wd (barely) aired my tires back up, and the ESC light went away after driving approximately 1/2 mile on pavement. 4wd worked again.
Went back to camp and looked some things up and decided to try 4Low and Sand/Mud mode. Made it about 4.5 miles on the sand when the same exact thing happened. Made it back to pavement, aired the tires up, drove for 1/2 mile on pavement and the error cleared again.
Any Ideas on where to begin trouble shooting? I cant imagine this is normal behavior? 4wd system shutting down when I'm using it?
Ran a scan with diagFCA and got the following stored codes:
ABS - Anti Lock Brakes
DTCM - Drive Train Control Module
EPS - Electric Power Steering
PCM - Powertrain Control Module
2020 trailhawk
No. | DTC code | DTC status | Description |
1 | C0051-62 | Stored | Steering Wheel Position Sensor - Signal Compare Failure |
2 | U0420-00 | Stored | Invalid Data Received From Power Steering Control Module 'A' |
1 | U0415-00 | Stored | Invalid Data Received From Anti-Lock Brake System (ABS) Control Module 'A' |
1 | U0415-86 | Stored | Invalid Data Received From Anti-Lock Brake System (ABS) Control Module 'A' - Signal Invalid |
1 | U0418 | Stored | Implausible Data Received From Brake System Control Module 1 |
