41 - 42 of 42 Posts
oh wow, I couldn't find any. I'm guessing they have the correct specs, as-in bolt pattern & off-set?
Yes, 5x110 bolt pattern, +40mm offset, 65.1mm center bore. And at 7.5'' wide, they are slightly wider than your OEM wheels, but well within the accepted range for 225 tires (6'' to 8'' wide rims).
If you Google X48510 wheel, you'll find plenty more of the same.
Reactions: rumrunner
41 - 42 of 42 Posts
