It's all good.
It's all good.Sorry...you were talking about mileage and such, didn't know you meant limp mode.
Thanks for the info.2014 Jeep Cherokee
OEM tires: 245/65-17 (750x245mm). Big Brakes. Bolt pattern: 5x110. Offset: +35 to +45 mm. Hub: 65.1. Lug: 12x1.25B. Backspace 6.5". Tires up to 790x265mm. Rims up to 24x9.0".
HH: The other comments about 5x110 bolts cover that. For the offset, get out your spare and check out the inside of the wheel for stamped info. On alloy wheels, offset is almost always there, and it may well be for the steel spare wheel, too. It'll say ETxx or something like that. HPHAnyone know the wheel bolt pattern and offset on the TH?...
If the above info is correct, and the hub is 65.1, that's the same as the Dart hub. Of course, reality is better than numbers. Once we know that spacer slides on, that's the proof in the pudding. We can make spacers and adapters happen within 60 days- faster if we can set up a group buy!Thanks for that info. Trying to get some wheel spacers.
