I get some tire rub with Falken P245/75r17 when turning ~45 deg. That's with 1/2" of the weld seam ground off. Never had that problem with the BFG KO2 LT235/80r17.
So you have AWD and put 235/70. Will a FWD fit that as well? Maybe even 245/70Here's my Latitude Plus/2.0T/ADI, with the HS lift, on 235/70r17 Nokian Rotiiva's, everything installed yesterday. Put a few miles on it before taking these, with no obvious noise increase. I definitely noticed the height increase when getting out, a slight drop to the ground that wasn't there in stock form.
You can. I'm running them.After searching for a couple hours I can't find an answer but I'm sure its on the forums here somewhere.
Anyone know if I can fit 245/70r17 KO2s on an MFC lifted AD1 with the stock 7" wide rim? I've seen members here that have done it with by upgrading to the TH rim but not sure if my stock rim is too narrow. My main concern is making sure I clear the suspension - I don't care to add spacers.
Thanks in advance!
I have a th with the dobinsons lift. I spent yesterday and today doing the pinch weld mod. The tech said that the front tires were hitting the front of the wheel well so bad that the wheels wouldn’t turn.What trim KL do you have? Sorry if I missed it. Your tires will fit a TH with the pinch weld mod. Hitting the liners is no big deal. You can reshape it out of the way with a heat gun or some trimmingWell I dropped of my th to get the Falken 265/70r17’s put on today. I just got a call from the shop saying the tires aren’t fitting because the turn angle is only about 30 degrees before they hit the liners. Guess I’ll send them back and get smaller tires.
Sent from my LG-H873 using Tapatalk
No lift, no spacers, stock wheels for cherokee limited 2014.BFG 255/55/18
Stock wheels, no lift.
UK based jeep cherokee limited 2014 model. 2.0litre diesel
Photos dont do justice. Need photos with tyre dressed.![]()
Sent from my SM-G973F using Tapatalk
