Any difference if you activate/deactivate the Speed Compensated Volume? I don't have a uConnect anymore (I replaced mine) but I recall a setting which was supposed to compensate for road noise when not at standstill.
Any difference if you activate/deactivate the Speed Compensated Volume? I don't have a uConnect anymore (I replaced mine) but I recall a setting which was supposed to compensate for road noise when not at standstill.Whenever I hook my phone up via the USB port to listen to podcasts or Amazon music, the volume is cut in half via the radio. It’s tolerable at a stand still, but then when you’re on the highway with road noise, it’s hard to even hear and understand. I’ve asked the dealership and they say that the firmware is up-to-date on the radio. I’ve tried maxing out the volume on my iPhone. Happens thru direct connect through USB and Bluetooth connect. Duplicated on the second iPhone.
has anyone else had this problem?
I do have this activated, makes no difference. I can hear regular radio fine anytime, use iPhone…not so muchAny difference if you activate/deactivate the Speed Compensated Volume? I don't have a uConnect anymore (I replaced mine) but I recall a setting which was supposed to compensate for road noise when not at standstill.
