I've purchased the 68191620AD hose with clamp. Though it is shorter in overall length than the OEM.I actually just ordered the parts a few days ago for my 2014 3.2 limited. Leaking at that stupid plastic quick connect. Hope this helps. You will also need a special clic-r pliers to remove those special fiat clamps and to reinstall them or install new ones. Good luck.
52014598AA CLAMP. Hose.
68185932AA CLAMP. Hose.
68191620AD HOSE AND CLAMP. Radiator Inlet.
68102127AD TUBE. Coolant inlet.
Did you ever complete the replacement of the upper radiator hose and the crossover pipe? I'm having a heck of a time trying to get the crossover pipe removed. I removed the nuts (red) for the welded brackets on the crossover pipe. Though I can't pull the pipe off because I'm locked in by the pressurized hoses (below yellow box). I'm wondering if I can loosen the two nuts shown in the yellow box or if that will depressurize the braided hoses. Any ideas?Does anyone have the part numbers for upper radiator hose and crossover pipe, that replaces the quick disconnect for 2014 Cherokee trailhawk? Thanks in advance.
Don't disconnect in the yellow boxed area else you'll vent and depressurize your A/C (that's the quick-disconnect between the compressor and condenser)Did you ever complete the replacement of the upper radiator hose and the crossover pipe? I'm having a heck of a time trying to get the crossover pipe removed. I removed the nuts (red) for the welded brackets on the crossover pipe. Though I can't pull the pipe off because I'm locked in by the pressurized hoses (below yellow box). I'm wondering if I can loosen the two nuts shown in the yellow box or if that will depressurize the braided hoses. Any ideas?
Thanks Gary. I hadn't chased the hoses prior to my last post but I did afterwards. Realized they are A/C lines.Don't disconnect in the yellow boxed area else you'll vent and depressurize your A/C (that's the quick-disconnect between the compressor and condenser)
