So I just very recently purchased a 2015 Cherokee Limited 3.2. I am pretty sure I am starting to have transmission problems. When accelerating up a hill from a stop it seems to want to stick in 3 gear, then when coming to a stop it wants to downshift hard. Also when accelerating it clunks into gear.
So it seems to downshift hard and has a clunk when accelerating.
My buddy said that I should check the transmission fluid but I am unsure that would do anything.
Is there anything I can do? According to the car fax, it has all the recalls and flashes done. But they were done in 2016 I believe. My VIN will be below if anyone wants to double-check if there is anything I may have missed or anything the dealer should have done.
I have read recently on this forum that there is a procedure for throttle calibration or throttle relearning I can try, basically just put the key in the run cycle and hold the gas for 20 seconds, then slowly let off the gas, then start. I also have a weird wobble that happens at low speeds. But I am not sure if that is actually a transmission or drivetrain issue.
If all else fails am I stuck with buying a brand-new transmission?
1C4PJMDS1FW556905
So searching for TSB I have come across the FCA Warranty Extension # X90 warranty extension, unfortunately, I don't think that this bulletin will apply to my Cherokee, which has 108xxx miles on it. I also am not the original owner of the vehicle.
1C4PJMDS1FW556905
