MY trailhawk 2015 has an external transmission oil cooler, and a dual fan behind the radiator, However, the dual fan system is not enough to cool the oil down when you drive on the sand. The system keeps overheating therefore the 4WD system shuts down until you stop and let the system cools down for 5 or 6 minutes. It's really annoying. I'm gonna install a second fan specif for the transmission oil cooler. I noticed that once you move the car (having only the froont wheels available) and get some airflow coming from the front of the car, the system cools down quickly. The radiator fan basically does not reach the transmission oil cooler. I'll try an extra fan before trying a second oil cooler,On the V6 the oil cooler is an oil/coolant heat exchanger and is located in the engine block 'V', so you won't see it externally. I believe all the V6 engines have them. Also I think all V6 models have the external transmission oil cooler but I'm not sure of that. The 'HD cooling' difference seems to be one vs. two radiator cooler fans, but I think all Trailhawk models get that with or without the towing package. It's all pretty difficult to sort out.
Are you sure it's the transmission that's overheating?MY trailhawk 2015 has an external transmission oil cooler, and a dual fan behind the radiator, However, the dual fan system is not enough to cool the oil down when you drive on the sand. The system keeps overheating therefore the 4WD system shuts down until you stop and let the system cools down for 5 or 6 minutes. It's really annoying. I'm gonna install a second fan specif for the transmission oil cooler. I noticed that once you move the car (having only the froont wheels available) and get some airflow coming from the front of the car, the system cools down quickly. The radiator fan basically does not reach the transmission oil cooler. I'll try an extra fan before trying a second oil cooler,
I’m sure about it, the temperature is reaching 115ºc when I drive on the sand. Once you stops, the temperature drop’s quickly back to 75º. It’s clear that the cooler size is to smallAre you sure it's the transmission that's overheating?
I remember years ago there were multiple reports of the 4x4 system overheating and shutting down after people had been driving on sand for a while, but it was always the rear diff (the RDM) that overheated, not the transmission.
The RDM has a clutch pack that allows variable power transfer to the rear wheels. It's this thing that causes a lot of heat build up when it's only partially engaged.
If I remember correctly, there was a TSB that updated some internal parameters in the RDM. This is circa 2015-2016 so it's been a while.
That is excessive. Maybe your oil cooler thermostat is malfunctioning and isn't opening. I'm pretty sure there are many people who do heavy off-roading, including in sand, as well as tow heavy loads at highway speeds, and they don't report any over-temp issues like this on the transmission.I’m sure about it, the temperature is reaching 115ºc when I drive on the sand. Once you stops, the temperature drop’s quickly back to 75º. It’s clear that the cooler size is to small
I’ll check this sensor, maybe the problem is there. But remember, I live in UAE, we drive under 115F temperaturesThat is excessive. Maybe your oil cooler thermostat is malfunctioning and isn't opening. I'm pretty sure there are many people who do heavy off-roading, including in sand, as well as tow heavy loads at highway speeds, and they don't report any over-temp issues like this on the transmission.
There is a thermostat that is part of the transmission cooler and it is supposed to open at 185F.
Ahh.. I did not notice that you lived in UAE. That high ambient temperature may definitely change things.I’ll check this sensor, maybe the problem is there. But remember, I live in UAE, we drive under 115F temperatures
Updating this treat..Ahh.. I did not notice that you lived in UAE. That high ambient temperature may definitely change things.
I myself had my first ever occurrence of engine oil temperature above the 2/3 mark of the temperature gauge a few weeks ago when we had a heat waver over here and it was 110F and I was climbing a mountain, going 55-65mph.
At the same time, the transmission temp had gone up to 200F, which is just about the highest I have ever seen it.
Admittedly, this is a very different situation, but I have done the same drive many many times and have pushed the cherokee just as hard, and temps have never gotten that high.
Typically, the engine oil temp will only ever go up to 2/3 on the scale, and my transmission temp never exceeds 180 going up the same mountain, even when towing my small utility trailer.
We always deflate the tires, which is the default action prior to the drive. Yes the sand is very soft and slippery, it's a fun challenge the desert drives we do here in UAEMany people here live in places like, say Phoenix, AZ, and I haven't seen this issue. I'm going with RDM overheating from possible sand driving technique. Are you dropping air pressures? That sand over there is like Glamis sand, equivalent of driving in very fine sugar...😎
