This is what mine sounded like a few years back before I had my roller rockers and cams replaced. If you guys sound even remotely like this get it repaired especially while under warranty.
First thing I did was check the oil. Full. Sat overnight. Next morning sounded like a spun bearing. As the engine warms up, the sound quiets to a light knock, and a tick. I was waiting for this to happen. Bad noises on a cold start up for a few seconds. Dealer could not reproduce the issue, I told them it will get worse.Check the engine oil level after it has not been run for a long while.
Seems to be very low mileage to be having rocker bearing failure.
Did the rock rails come from the factory? I had to do my rock rails as a dealer installed accessory.
