Thanks, but I did read it. You're just assuming I didn't, and you know what they say about that.
And no, that does not mean that the consumer was damaged by having to buy another one. It means that in 100% of the cases either the dog or the person was injured, even though the harness was used. Therefore, 100% failure rate.
Either the dog was hurt in the crash or the person was hurt by a flying dog, or, most likely, both.
On a positive note, at least your three takeaways are correct.
First, my apologies... I glanced at the post and searched the web for the info. It was posted with the 100% failure rate title. I should have read the post more carefully and then read the original report as you did.
I agree with the study - it's purpose and conclusions. However...
My concern is and was that saying there is a 100% failure rate will be read by many people to mean: 1) That they are worthless and it's better to NOT use them and 2) that the 100% failure rate applied to ALL dogs. The study focused on large, 50-85lb dogs. It did not include testing with small dogs. And if there is a danger from a "flying dog" to humans when the harness failed, then imagine what it would be like if there were no harness to slow them down.
My wife and I have been using a dog harness for years. One time, I had to make an emergency stop to avoid hitting another car. The harness and the seat belt to which it was attached stretched, and our 17lb dog's body moved partially between the front seats before stopping him. He was shaken up a bit, but he was fine after a few minutes. If he had NOT been wearing the harness, he would have hit the front dash and been severely injured or killed.
I'm not arguing they the harnesses are completely safe. I'm pointing out that this is one study, under one set of conditions, and it focused on large dogs. There is not a 100% failure rate for all dogs under all conditions. If I'm mistaken, please post references.
Maintaining the safety of our puppies is critical. We absolutely should have standards for safety and the companies should be held accountable if they fail to meet them. That said, balancing the pluses and minuses of current safety harnesses, it's better to use a good safety harness than no harness (IMO).
Dan.
