I would not for two reasons-you are changing from a 0w to a 5w which would be a very major difference and you would be reducing protection by decreasing from a 40 to a 30-how about a 0w50 instead?
Factoid: owners of '19 1500 3.6 Rams can use either the 5w-20 OR 5w-30 should the former not be readily available-I find this interesting even though its the 3.6 NOT the 3.2.
Do you truly believe that the 5w-20 really does not sacrifice maximum service life for corporate fuel economy compliance/mandates?
There is a not a major difference between 0W and 5W, in the same grade range, until you get into the -20 to -30F range. The SAE J300 Mini-Rotary Viscometer cold weather pumpability test is done at -40C for 0W and -35C for 5W, so they’re isn’t much difference in viscosity until you get into extreme conditions.
All oils are chosen by the auto manufacturers to meet various test parameters such as wear protection, fuel mileage, cost and cold weather performance, so obviously there is going to be some compromises made in each category in order to recommend an oil that works satisfactorily for most consumers.
Will a 5W-20 provide less wear protection than a Porsche A40 rated 0W-40? Probably (maybe, possibly) under some/most conditions at the expense of fuel mileage but would the average Jeep owner ever see a real world difference in the life of the engine? A 0W-40 with the appropriate GM, Porsche,FCA, MB and VW approvals is arguably the “best” oil available for wear control and extreme cold weather performance, so why isn’t it recommended in every vehicle FCA sells?
