If you’re referring to the Platinum 5W-30 I use in the 2L it most certainly is compliant. The material standard for the turbo is MS-13340, not MS-6395. Pennzoil synthetic is the factory fill for the turbo.
That's what I use in mine. I probably would be a little more concerned if I were running a Pentastar, then again, thank goodness I knew better...😎If you’re referring to the Platinum 5W-30 I use in the 2L it most certainly is compliant. The material standard for the turbo is MS-13340, not MS-6395. Pennzoil synthetic is the factory fill for the turbo.
Agreed on the Pentastar. Thank you for the kind words, just retired after 41 years with the ISP.That's what I use in mine. I probably would be a little more concerned if I were running a Pentastar, then again, thank goodness I knew better...😎
Also, I'm assuming that you are a proud member of the ISP, and just want to say thanks to you and your fellow Troopers of the great state of Indiana for your dedicated service...😎🇺🇸🚔
If it were the Italian closed deck or semi closed design I would have gone that route its really just another budget open deck DI engine with a blower to add the extra stress/flex-no thanks give me a simpler 6 cyl with more towing capacity and no forced induction/direct injection.That's what I use in mine. I probably would be a little more concerned if I were running a Pentastar, then again, thank goodness I knew better...😎
So, it's just a coincidence that the 2.0T is well on the way to being the most dependable Jeep engine since the 4.0 then huh??? I sure see a lot more posts about Pentastars issues than I have about the 2.0T, in fact, I don't think I've seen any yet...Just saying...😎If it were the Italian closed deck or semi closed design I would have gone that route its really just another budget open deck DI engine with a blower to add the extra stress/flex-no thanks give me a simpler 6 cyl with more towing capacity and no forced induction/direct injection.
Proof positive that a 5w30 is better for severe applications, no?
Just curious, how long as the 2.0 been around? 2018? If that is correct, I'm not sure how anyone could make long term predictions on longevity, right?So, it's just a coincidence that the 2.0T is well on the way to being the most dependable Jeep engine since the 4.0 then huh??? I sure see a lot more posts about Pentastars issues than I have about the 2.0T, in fact, I don't think I've seen any yet...Just saying...😎
No, because one could argue that a “light” API 5W-30 doesn’t provide adequate protection for a turbo and was only chosen for CAFE and that it would be protected “better” using an oil with ACEA C3 and Porsche A40 or MB 229.5 approvals in a 5 or 0W-40 or a “heavy” 5W-30 like Platinum Euro L.Proof positive that a 5w30 is better for severe applications, no?
2019 model year, but those were already on the road early in 2018, and there are a bunch getting up there in miles now. Also, find me a post about engine related failures on this forum involving the 2.0T...Again, that's not just a coincidence. I'm all ears!!!😎Just curious, how long as the 2.0 been around? 2018? If that is correct, I'm not sure how anyone could make long term predictions on longevity, right?
So that answers it for me. The engine is too new to make claims of long term reliability.2019 model year, but those were already on the road early in 2018, and there are a bunch getting up there in miles now. Also, find me a post about engine related failures on this forum involving the 2.0T...Again, that's not just a coincidence. I'm all ears!!!😎
Maybe, maybe not. BMW, Porsche, and Volkswagen use 0W-20 in some of their turbocharged engines, as does GM, Honda and Lexus that I can think of off the top of my head.I am trying to sort out my oil concerns and the simple fact that a higher stressed turbo four uses 5w-30 instead of 5w-20 pretty much answers my question.
Just how long, how many miles, and how many units in service does it take to gain "Reliable" status???😎So that answers it for me. The engine is too new to make claims of long term reliability.![]()
