1 - 10 of 10 Posts
I have a 15 trailhawk , does not have the subwoofer or upgraded system, I was curious if I could tap into the door speakers in the rear if so does anyone know what color I tap into? I would like to avoid pulling the head unit to tap in a line out converter. I have searched all over and I cant seem to find what color wires to tap into. Any info would be amazing, thanks fellow jeepers.
On mine I tapped in behind the display for the front speakers. It was easier than pulling door panels. Comes right out.
Left Front Speaker (+/-) gray/purple - gray/yellow
Right Front Speaker (+/-) dk. green/purple - dk. green/yellow
2015 Cherokee Trailhawk
Just curious, but wouldn't that connection method send a full frequency signal to the sub or will you add a crossover there to allow only low frequency signals?
Thought I saw somewhere that the 9-speaker harness was run in all 6 and 9 speaker vehicles, but since my brain is not operating as well as in my youth (ha!), then maybe I only thought that Jeep would do that, but it actually didn't happen...
Reactions: SamstrailhawkKL
Discussion Starter #4
I'm not to well versed on this stuff, I'm assuming I would need to run those connections to a line out converter right ?
You would connect: Speaker wires > Line Out Converter > Low-Pass Crossover > Amplifier > Subwoofer.
Make note that many amplifiers have a built-in crossover; some even accept speaker level inputs. You can even buy some self-contained Subwoofer packages that accept Speaker-level input wires (do they still make/sell Bazooka Subs?!?). Shop around and figure out your options.
Discussion Starter #6
Thanks, and believe it or not they do make bazooka tubes and from what I've read they actually sound pretty good inside. I'm not looking for a system people can hear from down the road, I'm now 34, that stage of my life has passed, but I still like to feel the music in my car
I use the 12-volt outlet in the cargo area. I have it in the switched position so it is only live when the vehicle is on.
Thank you guys for so many good tips thanks to them I managed to wire my subwoofer easily but after this, I found out that I have some problems with the speakers, the sound was very blurry and I had no idea what to do. At first I thought that the problem is with the cables connection but after I checked all connections and changed them the problem was still there. So I decided to call my friend that works in this area and he told me that the problem for sure is in the speakers, so I decided to change them, but I didn't want to buy the same model because I was afraid that even if I buy a new one the problem will not be resolved, so my friend recommended me a site with good reviews where I found some good speakers.
1 - 10 of 10 Posts
