Stilettos Installed…..finally
457 Views 2 Replies 2 Participants Last post by  Flechtight
3
Wheel Tire Car Vehicle Automotive tire
Finally got time to myself this weekend and installed the Dobinson 2” version Stilettos.
I’ve been running on Dobinson plus 1/2 hazard sky lift for a couple of years. Decided to just go the 2” and clean things up.
Wheel Tire Automotive tail & brake light Hood Vehicle
Install was not that hard, hardest part was cutting off the one mounting bolt that doesn’t clear the RDM. A 4 1/2” cut-off wheel barely gets the job done.
A second set of “handy”hands would greatly speed things up
I have two adjustable caber links yet to install, then off for an alignment
On the down side, as I was resetting the front height , I noticed oil on the sun frame, and front skid plate. the oil transfer line on the transmission leaking, cheap plastic fitting to rubber tube. Don’t know for how long, so I’ve got a new hose and o-ring on order, then have to take it on the dealer and have the level checked
Flash photography Automotive fuel system Gas Automotive tire Automotive wheel system
See less See more
Reactions: 5
1 - 3 of 3 Posts
sweet! time to find a river crossing!
too many inferior plastic connectors on these Cherokees
Reactions: 1
2
Another piece of the puzzle installed today. This one was pretty easy, just had to re- orient the zerk from say 8 o’clock to 7 o’clock for access
Next …. Adjustable Trailing arms.
See less See more
Reactions: 4
1 - 3 of 3 Posts
