Roof rack + lights - Install
34K views 35 replies 21 participants last post by  Aceman
Awesome installs!!
I can vouch for the el-chepo LED lights. They work just as good as the expensive ones. One pointer, take them off ASAP and open them up. Get some clear silicone and silicone all areas where the light opens and then a dab of silicone in each screw hole. This will save you some headache down the road. I got the same ones and both of them started to obtain moisture on the inside. I had to take them apart and run a hair dryer through them to dry it up. I then silicone it shut and haven’t experienced and moisture since then. I live in Washington State so we have a lot of rain.
A couple questions, can you provide links to the cross rails and the basket you purchased? I really like the low profile look of yours and like how you were able to use the factory roof racks. If there is any other hardware or items you needed for the roof rack can you please also explain?
Thank You
-Meeko
