1 - 5 of 5 Posts
Since a few days, after I start my 2019 Cherokee, the right signal light, daytime running light and regular headlight stop working after about 3 minutes.
could this be a fuse and if so, where can I find these fuses in the car?
Thanks in advance
Fred
Sounds like a heat-related issue. A blown fuse would mean those things would work at all.
Heat issues are a bear to find. You can get a can of electronics freeze spray and hit anything that looks interesting to see if the problems resolve themselves. Other than that, good luck!
Reactions: Ferry van Lier
2015 Cherokee Trailhawk
True about the fuse - when it opens, that's it and would both sides be on the same fuse? It absolutely sounds like it's heat-related. Have any of the lights been changed out (mods, etc.) or area(s) repaired?. Go into 'Settings' and unselect 'Daytime Running Lights' o get those out of the equation and then break it down from there.
I'd start with the plug to the Headlamp Unit, all those lights are on separate circuits...
But the Ground Wire from the Headlamp Unit is common for all circuits...
So my guess is a loose/bad ground, or the plug is not seated...
There is also an intermediate plug for it XY102A somewhere along the harness that could be loose, but I can't tell you where that is located...
Good Luck! :cool:
1 - 5 of 5 Posts
