1 - 11 of 11 Posts
I am thinking about buying a set it said on the website they will fit. I am curious if it might give it a lift or stay as OEM height. Is it worth spending the money on it?
http://www.4wheelparts.com/Suspension/2-Front-Pro-Runner-Adjustable-Shocks-and-2-Rear-Pro-Runner-Monotube-Shocks.aspx?t_c=1&t_s=90&t_pt=3306&t_pn=S/DShockingZXCombo#questions_Container
Also came across these too I had a set on my Pathfinder and worked very well would rise and lower manually depending on terrain
http://www.4wheelparts.com/Suspension/4-Rancho-RS9000XL-Shocks-with-4-Red-Shock-Boots.aspx?t_c=1&t_s=90&t_pt=3306&t_pn=S/DShockingRS9000XL#overview_Container
Super Moderator
Are you aware those won't fit? Currently the only aftermarket shocks and struts I've found were from RRO. You can likely replace the rear shock with something off the shelf for sure if you can make sure to find something with the right specs. However the front strut is something else entirely because of the way it mounts to the jeep.
Discussion Starter #5
I recently went into the store place an order for the rancho shocks. The sales rep confirm they fit.
Super Moderator
Front and rear? Because I know for sure they may only fit the rear.
Super Moderator
If so, they have peaked my interest. I'd be interested to see what comes. Hope they realized it was a Cherokee and not a grand Cherokee. I've had people make the mistake ALL the time.
something doesn't seem right here, I didn't talk to a sales rep but went on the web site to purchase the shocks to see what happened. I put in a order for 2015 cherokee, 2013 grand cherokee and a 2007 ford ranger and the same part number came up for all 3 vehicles
Discussion Starter #10
Got a call from 4wheel parts they sadly informed me that the parts don't fit and return my money. I am going to order a Budget Boost Lift Kit - Hazard Sky lift soon.
Super Moderator
I can't say I'm surprised with 4wp response. Many shops make that mistake thinking they can then discover they can't.
1 - 11 of 11 Posts
