Hi guys
I'm hoping someone can figure this out.
I have a 2015 TH but it did not come with the homelink. So I got a 2014 Sun Visor with the homelink and swapped the visors.
The 2014 visor vanity lights work but the homelink led does not. (no matter what button is pushed or even when trying to erase the previous programming)
The led just will not light up!
The dots on the buttons seem to be ever so slightly illuminated but I need to cover them with my hands so I can actually see it. When I press a button, that illumination turns off for all the buttons. I pressed each button and they all seem to kill the illumination on all the buttons
I have plugged in the 2014 visor on the passenger side as well since it has the 3 pin connector as well.
There was a link from techauthority that gave schematics on wiring but it does not appear to be working anymore
I keep thinking that the homelink module is not getting power but I have no sure way to test it. I hooked up a cheap 12V battery to the visor and the vanity lights work but I get nothing from the homelink. Of course in this case I am only powering 2 of the 3 pins.
I am beginning to think that the module is dead or the wiring in the visor is messed up. I tried to split open the visor but I can't bring myself to wreck it even more. I have removed the vanity light shell and was able to look inside the visor a bit and I see 3 wires (1 red, 2 white) going into the module and they look fine from the angle I could see from.
I am losing my mind not being able to get this working. Does anyone have any ideas?
I was also wondering if they switched the wiring/polarity on the connectors between 2014 and 2015?
I was going to do a makeshift jumper wires and switch the polarity on the pins but then I accidentally let the wires touch and I blew a fuse. Got so mad that I had to go get a fuse that I didn't end up finishing that test.
Hoping someone can give some insight.
