41 - 60 of 3353 Posts
You can't add a full size spare unless you get the tow package. Also why would they list a compact spare tire as standard for one model and as an available option on the other 2 models? This isn't the first car I'm buying so I know the ropes... Would like to know where on the website you see it listed as standard
· Banned
Here you go, straight from the Jeep website: Scroll down to where I placed the stars.
MODEL
CHEROKEE LIMITED 4X4
Show What's Included
Show Standard Features
Model HighLights
Key Features
Additional Key Features
Brake Stability Control
Hill Start Assist
Trailer Sway Damping
Driver Inflatable Knee-Bolster Airbag
Passenger Inflatable Knee-Bolster Airbag
Supplemental Front Seat-Mounted Side Airbags
Supplemental Side-Curtain Front and Rear Airbags
Supplemental Rear Seat Side Airbags
Jeep Cargo Management System
Illuminated Front Cup Holders
Keyless Entry with Panic Alarm
115-Volt Auxiliary Power Outlet
Tilt / Telescope Steering Column
Bi-Function Halogen Projector Headlamps
LED Daytime Running Headlamps
LED Tail Lamps
Deep Tint Sunscreen Glass
Leather-Wrapped Steering Wheel
Ambient LED Interior Lighting
Power Front Windows w/ 1-Touch Up and Down Feature
Fog Lamps
ParkView(TM) Rear Back-up Camera
Remote Start System
Universal Garage Door Opener
Passive Entry / Keyless Go(TM)
A/C Auto Temperature Control with Dual Zone Control
Exterior Mirrors with Turn Signals
Exterior Mirrors with Courtesy Lamps
Exterior Mirrors with Heating Element
Heated Steering Wheel
Auto-Dimming Rearview Mirror w/ Microphone
Automatic Headlamps
Remote USB Port
Windshield Wiper De-Icer
Leather-Wrapped Shift Knob
Tonneau Cover
Heated Front Seats
Engine/Transmission
2.4-Liter I4 MultiAir® Engine
9-Speed Automatic Transmission
Selec-Terrain™ System
Jeep Active Drive I
All Speed Traction Control
Electronic Roll Mitigation
Multimedia
8.4-Inch Touch Screen Display
Uconnect® 8.4A AM/FM/BT/ACCESS
Uconnect® Voice Command with Bluetooth®
SiriusXM Satellite Radio w/ 1-Yr Radio Subscription
Remote SD Card Slot
Audio Jack Input for Mobile Devices
Remote USB Port
6 Speakers
Seating
Leather-Trimmed Bucket Seats
Heated Front Seats
Power 8-Way Driver Seat
Power 4-Way Driver Lumbar Adjust
Front Seat Active Headrests
6-Way Manual Passenger Seat Adjust
Front-Passenger Fold-Flat-Forward Seat
Passenger In-Seat Cushion Storage
Rear 60 / 40 Folding Split Recline Seat
Rear Armrest with Cup Holder
Wheels/Tires
18-Inch x 7.0-Inch Polished Aluminum Wheels
225/60R18 BSW Touring Tires
Tire Pressure Monitoring Display
EPA Est. MPG
22 city/29 hwy
Interior & Exterior
Additional Features
"4X4" Badge
"Jeep" Badge
"Limited" Badge
1-Year SiriusXM Radio Service
12-Volt Auxiliary Power Outlet
12-Volt Auxiliary Power Outlet in Instrument Panel
12-Volt Cargo Power Outlet
140-MPH Primary Speedometer
15.8-Gallon Fuel Tank
160-Amp Alternator
2 Front Overhead Incandescent Map Lamps
3 Passenger Assist Handles
6 Month Trial (Registration Required)
7-Inch Multi-View Display
730-Amp Maintenance Free Battery
8 Cargo Tie Down Loops
Accent / Body-Color Fascias
Active Grille Shutters
Air Filtering
Anti-Lock 4-Wheel Disc Brakes
Automatic Headlamps
Auxiliary Transmission Oil Cooler
Battery Run Down Protection
Black Headlamp Bezels
Black Lower Driver Cladding
Body-Color Door Handles
Body-Color License Plate Brow
Bright Day Light Opening Moldings
Bright Exhaust Tip
Bright Side Roof Rails
Cargo Compartment Lamp
Cargo Net
Center Console Parts Module
Chrome Grille Surrounds
Compact Spare Tire
Conventional Differential Rear Axle
Cruise Control
Door Parts Module
Driver Seatback Pocket
Electric Power Steering
Electronic Park Brake
Electronic Range Select
Electronic Vehicle Information Center
Engine Immobilizer
Engine Oil Cooler
Enhanced Accident Response System
Fog Lamps
For Details, Go to DriveUconnect.com
For More Information, Call 800-643-2112
Front / Rear Climate Control Outlets
Front and Rear Floor Mats
Front Brake and Knuckle Parts Module
Front End Parts Module
Front Fascias Parts Module
Front License Plate Bracket
Front Passenger Seat Belt Alert
Front Suspension Damper Parts Module
Full-Length Floor Console
Glove Box Lamp
GPS Antenna Input
Headlamps with Turn-Off Time Delay
Headliner Parts Module
Height-Adjustable Front Shoulder Belts
Hill Start Assist
Humidity Sensor
Illuminated Entry
Instrument Panel Parts Module
Jeep Rack Kit
LED Tail Lamps
Lock On Sync Tire Press Sensor
Locking Glove Box with Damped Door
Media Center Electronics Storage (USB, SD, Aux)
NAV-Ready. See Dealer for Details
Normal Duty Suspension
Occupant Classification System
Overhead Console with Sunglass Holder
Power Fuel Filler Door Release
Premium Air Filter
Premium Interior Accents
R1234YF Air Conditioning Refrigerant
Rear Brake and Knuckle Parts Module
Rear Reading / Courtesy Lamps
Rear Seat Heat Ducts
Rear Spring Parts Module
Rear Window Defroster
Rear Window Wiper / Washer
Remote Proximity Keyless Entry
Remote Start System
Remote USB Port
Seat Parts Module
Security Alarm
Sliding Sun Visors with Illuminated Vanity Mirrors
Steering Column Cover Parts Module
Tachometer
Temperature and Compass Gauge
Three Rear Seat Head Restraints
Tip Start
Tire and Wheel Parts Module
Tonneau Cover
Uconnect® Access
Underbody Aerodynamic Treatment
Variable Intermittent Windshield Wipers
Vinyl Door Trim Panel
Climate Control Options
Exterior Paint Procedures
Monotone Paint
Glass
GVWR Packages
GVW Rating - 5,500 Pounds
Mirrors
Body-Color Exterior Mirrors
Power Multi-Function Mirrors with Manual Fold-Away
Sound System Components
Integrated Voice Command with Bluetooth®
Remote SD Card Slot
Removable Short Mast Antenna
Steering Wheel Mounted Audio Controls
Speaker Systems
6 Speakers
Tires
Wheels
Performance
Engine
Transmission
Safety & Security
Convenience/Security Options
Advanced Multistage Front Airbags
Child Seat Anchor System-LATCH Ready
Heated Front Seats
Speed Sensitive Power Locks
Dimensions & Capacities
Exterior Dimensions
Ground Clearance - at curb weight - Approach Angle:18.9
Ground Clearance - at curb weight - Breakover Angle:19.5
Ground Clearance - at curb weight - Departure Angle:25.0
Ground Clearance - at curb weight - Running Ground Clearance:8.2
Overall Body Width:73.2
Overall Height:66.2
Overall Length:182.0
Overhang - Front:Not Available
Overhang - Rear:Not Available
Track - Front:62.0
Track - Rear:61.9
Turning Diameter - curb-to-curb - Left:37.7
Turning Diameter - curb-to-curb - Right:37.7
Wheelbase:106.3
Interior Dimensions
Cargo Capacity (Trunk):29.7
Head Room - Front:39.4
Head Room - Rear:38.5
Hip Room - Front:53.8
Hip Room - Rear:49.9
Leg Room - Front:41.1
Leg Room - Rear:40.3
Passenger Interior Volume:105.4
Seating Capacity - Maximum Seating:5
Seating Capacity - Standard Seating:5
Shoulder Room - Front:57.6
Shoulder Room - Rear:55.1
Trunk Lift-Over Height:30.9
Capacities/Weights
Base Curb Weight - Automatic Trans:4044
Capacity/Weights - Fuel Tank Capacity:15.8
Capacity/Weights - Gross Vehicle Weight Rating (GVWR) :Not Available
Payload Capacity - Standard:Not Available
Towing Capacity - Maximum:4500
Towing Capacity - Standard:2000
Weight Distribution - Automatic Trans - Front :57.0
Weight Distribution - Automatic Trans - Rear:43.0
Basics
Brakes - Front:Disc
Brakes - Rear:Disc
Driveline Configuration:4WD
Maximum Number of Doors:4
Steering:Rack & Pinion
Suspension - Front:Ind
Suspension - Rear:Multi-Link Ind
Tires - Aspect Ratio:60
Tires - Construction:R
Tires - Spare Tire Type:Compact
Tires - Type:p
Tires - Wheel Diameter:17.0
Tires - Width:225
Vehicle Type:Sport Utility
Mobility
Body Opening Width :31.6
Open Door Angle:65
Open Door Trim to Body:3.0
Seat Cushion Height from Ground:28.5
Seat Cushion to Rocker Panel:9.4
Step-Out Height :3.4
Step-Out Width:8.8
Step-Over Height from Ground:17.8
Warranty
Basic - Miles:36,000
Basic - Months:36
Powertrain - Miles:100,000
Powertrain - Months:60
Roadside Assistance - Miles:100,000
Roadside Assistance - Months:60
Rust-Through - Miles:100,000
Rust-Through - Months:60
Respectfully, macfan, you have presented yourself as the foremost authority on all things jeep because you live near their HQ. I'm down the street from the King Center, but that doesn't make me the authority on MLK. My build sheets, the one from the dealer and the one from JG you get after your vehicle is built does not mention a spare of any kind, full size or compact. I questioned it at the time of my order because I have never purchased a car without one before.
At the same time, the build sheets don't mention all the nuts and bolts either, so I could be wrong, **** I hope I am wrong, but at least I'm willing to admit that.
The crow is on the table. I will happily pick up a fork and knife, strap on a bib and dig in if I am in error. I hope you can do the same.
· Banned
At the same time, the build sheets don't mention all the nuts and bolts either, so I could be wrong, but at least I'm willing to admit that.
Sorry, if I come on too strong for some of you. But it irritates me when sales people do not know their product. I am not asking anybody to eat crow but do want you to do your research and stop relying on what your dealer tells you. They are the last people to know anything. Even Auburn Hills will tell you that. Again, sorry you don't like my Auburn Hills reference but I am trying to tell you most people in mid and southeast Michigan eat, sleep, and breath cars. Our whole economy is built/based on that. I don't know anybody in my area that is not connected with the auto industry in some way.
· Banned
I did my research as my picture showed I wasn't just relying on the dealer...
This discussion is stupid. At this point I am not really going to worry anymore about trying to explain things to you. I am sorry your Jeep is not coming with a standard compact spare tire but mine is. You know where to find me to confirm that I am correct. I am not surprised your sales person is uninformed. I had to school my salesman on the differences between the two Uconnect systems and the Chrysler dealer zone rep about the VOTS system sending out emails. I will keep what I know to myself from now on. Silly me I thought this was a place to exchange information.
You know what is stupid is that both of us have proven that Jeep has put out conflicting information and you are still acting condescending... I am sorry you know everything we will just agree to disagree and hopefully we are all taken care of- now can we get back to the fact that we all can't wait to have our Cherokee's in hand!
I emailed my dealer, so I'll let you all know what he says. My Jeep is already ordered and I did not add or subtract or even say one word about a spare tire, so this should be a pretty good test of whether or not you automatically get one. :)
I guess the important thing is to know you have a wheel at every corner :)
Geoff
I alled and asked another dealership just to check- their response was Chrysler Group is putting out most 2014's with no spare including most Cherokee's... I said well there is conflicting information on the Jeep website and they had no answer.
· Banned
Since you won't take my word would you accept information from Cherokee Steve one of this sites moderators?
Look at the second from the bottom line on his grid. I will admit the compact spare is not standard on FWD models but I don't think any Jeep enthusiast on this site would order a FWD model. The only time you do not get a compact spare as standard equipment on a 4WD model is if you order the trailer towing package. In that case you get a full size spare. Yes, Chrysler is cutting corners/expenses by eliminating the spare tire in FWD models. Please forgive me for being on my soap box but I am irritated by sales people and dealerships who do not know the product they are selling.
https://docs.google.com/spreadsheet/pub?key=0Aq6au4G-dN4adDFWdHAzWmxyRm1PemQtQnNjcTV1OHc&output=html
Ok and I am getting a FWD model- so my salesman was correct. I am a Jeep enthusiast but don't need an AWD - I want the better MPG so I am going with FWD. And I can't have a car because I am handicap I need the height of an SUV and I want the Cherokee plain and simple... (not that I need to explain myself but before the criticism begins I figured I may as well...)
This is what the Jeep Canadian website is showing
2x4 = None
4x4 = Compact
4x4 Trailhawk = Full-size
Makes sense then. Mine is a FWD as well. I can't call myself a jeep enthusiast either, being this is my first American car. Because of this whole production snafu, it will probably be my last. I picked the Cherokee for size, features and pricing, not because I planned to go mud-dogging or rock-slinging. I'll stick with it because I think it will be a great vehicle, but there is definitely a bad taste in my mouth.
