Hey All!
Recently I've been running into an issue in my Trailhawk where unlocking the vehicle via passive entry does not unlock the driver side door. All other doors unlock successfully except the driver side. This does not happen every time I use Passive Entry but it is becoming more common.
If Passive Entry fails and I then try to unlock it using the key fob the driver side door still will not unlock. The only way to unlock the driver's side at this point is to get in through the driver side rear or passenger side door and unlock it manually. Has anyone else experienced anything like this with Passive Entry on their KL?
Thanks!
Thanks!
