im sure at some point they will say whatever damage was caused was due to the owners negligence. i bet they'll have some sort of rating for it.Seeing all these commercials for the Trailhawk has me curious too on whether if it actually is able to perform on all terrains or is it just purely for marketing. In a long run if you decide to take the Cherokee off road often will there be damage in the differential and transmission?
The Trailhawk line wouldn't be Trail Rated if it couldn't at least do some off-roading so I think it will perform ok - obviously not as good as a smaller Jeep Wrangler but it won't be incapacitated out there.Seeing all these commercials for the Trailhawk has me curious too on whether if it actually is able to perform on all terrains or is it just purely for marketing. In a long run if you decide to take the Cherokee off road often will there be damage in the differential and transmission?
CT,I think the Cherokee will be better off-road than the Wrangler is on-road. For really serious off-roading, clearly you'd buy a Wrangler and mod the heck out of it-- not that it's a slouch in stock form! Choose the Cherokee if you want a vehicle with road manners and efficiency, and the fun still doesn't have to end when the pavement does : )
The 4x4 concern is true in my 1995 Z071... not in my wrangler, different system.I know if you have 4WD and get stuck, it can be a problem get it to switch into 4WD. Would an AWD have an advantage in this case?
didnt know that as im new to jeeps, why does it get stuck like that?I know if you have 4WD and get stuck, it can be a problem get it to switch into 4WD. Would an AWD have an advantage in this case?
Most 4x4 Systems require a little movement to engage the 4WD. If you are stuck in the Mud, its too late. Its always better to turn on 4wd before you get stuck. A side effect of AWD is that you wouldn't have that concern.didnt know that as im new to jeeps, why does it get stuck like that?
So is the only way to push it or move the wheels slightly to activate the 4wd again?Most 4x4 Systems require a little movement to engage the 4WD. If you are stuck in the Mud, its too late. Its always better to turn on 4wd before you get stuck. A side effect of AWD is that you wouldn't have that concern.
I'm not sure about the rear locker though, I've never had one. Does anyone else know about that?
