MOPAR vs. K&N Oil Filter Comparison
1 reading
54K views 34 replies 19 participants last post by  fusseli
#1 · (Edited)
I just did the first oil change on my TH with a Mopar filter and I have been previously inspired by filter comparisons on Youtube. It's amazing how widely the build quality can vary on the metal can type filters. With the exposed filter there is less to hide. Anyway, here is a comparison of the Mopar M0-349 and K&N PS-7026 which is a new filter design for 2014+ Chrysler engines. The K&N was $11 with free shipping direct from K&N, and the Mopar was $11 at my dealer.
I can say right off the bat that the build is different. The K&N is definitely not a copy with red filter media. The plastic molding is different thickness (thicker on the K&N). The ends of the filter are put together in different ways, the Mopar is glued (?) together whereas it looks like the K&N filter media is cast into the end piece. The center structure build and attachment to the filter is different, the Mopar is solid with a tight fit whereas the K&N has some play in the center structure and can be turned. The large o-rings appear the same.
Pleat count: Mopar 60, K&N 48 (!!)
I can't really comment on the filter media. The K&N has a "fluffy" look to it up close and is perfectly flat, where the Mopar has tiny ribs. Both Mopar filters I got have the dark stain on the media out of the box.
Any thoughts, observations, speculation, or other discussion is welcome! If you'd like to see any other picture or have me test something just say so. It's tough to say which looks better, especially with the different pleat count and different media.
The K&N p/n cross reference on the box is:
Champ Labs P1009
Luber-iner P1009
Chrysler 68191349AA
Mopar M0-349
Fram CH11665
Purolator L36296
Service Champ CF6296
#2 ·
They look similar. I guess we'll have to wait for some 'scientific' tests to see which is superior. Thanks for posting!
#3 ·
I have always found that the Champion Labs filters products are the best value. They make many filters for other companies oem and aftermarket
#4 ·
Personally I'd go with the Mopar (more cleats is good , right ? :) ) K&N had a bad rep on a Dodge Cummins forum I was on , I did actually use their Oil filter for the Cummins without issue , But glad when I swapped it out for a Baldwin.
#7 ·
If the engine fails and the cause is due to lack of lubrication (as determined by the dealer) will K&N pay the bill? I'm not even saying the filter would have to be the cause but in the minds of the manufacturer it is a way out. I always stick with OEM filters while under warranty.
My .02
Reactions: Good1Brian and 007
#10 ·
I am shocked to see it is made in Korea. When I had my Frontier with the 4.0L in it I ran K&N oil filters. And the same on the ex's Patriot with the 2.0L. They were both made in USA.
I am not a fan of the air filters from K&N. But I would like to see the results of the oil filter. Thanks for sharing OP.
#12 ·
Cool! I'll be switching over to K&N for the oil filter at my next oil change! Interesting on their pleat count more pleats usually means more flow, but you can't compare surface area and flow rates unless you compare the properties of the filter media itself. Makes me curious about if the flow rate could actually change the efficiencies of our motor given it already has a variable displacement oil pump.
I have their engine air filter and now I can only hope they release a re-usable in cabin air filter for the cherokee's.
Yep I bet cartridge filters require special plastic injection molding etc. since there is no old style metal can to support the media. Like you said must be where their factories are with those capabilities.
#13 ·
Mopar-K&N-Fram comparison
We can scratch that theory :wink:
I picked up a Fram CH11665 for the 3.2L Jeep at Walmart today for about $6. It has pleat count of 60 (same as MOPAR) and is of a third/different type of construction. The Fram is glued/molded at the ends like the K&N (48 pleat), and says made in USA unlike the other two. The filter media is similar in appearance but possibly different than MOPAR, notice the folds in the pleats look slightly thicker. The seam where the ends of the media meet have a wide gap on the Fram.
#17 ·
I'm counting 62 pleats on the new 68191349AB (Package still says Mopar M0-349), this is up from 60 I counted on the original AA. Otherwise construction is visibly the same at the older Mopar (but different than Fram and the K&N).
#18 ·
It could be a coincidence, but now that I am running the AB version I don't notice rattle at startup as often as with the older AA filter. I'm not sure how the cartridge could have an impact on that though.
#19 ·
Hmmm... I'm intrigued. I just ordered a couple of the ABs, because I hate that startup rattle. I'll let you know if it makes a difference with my engine. I'm using a K&N right now.
#20 ·
Also check e-bay for price. Picked up 3 Mopar filters the AB type for just under $5 inc shipping from a Jeep dealer on the East Coast.
These boxes also state, only for 2014 and later engines. Avoids the confusion of using an identical 2013 filter. That will produce lower oil pressure from what I understand.
The pricing for these filters are all over the board.
I just give the filter to the lube shop when I get my change. Avoids the $15 upcharge for the Mopar filter.
#21 ·
Fram XG vs. Mopar oil filter for KL 3.2L Pentastar
The Fram Tough Gaurd (TG) and Ultra (XG) are finally available to me locally so here's a comparison of the regular Fram CH, TG, XG, and the updated Mopar AB. Close up photos are the Mopar (AB version) vs. the Fram XG.
The XG is very desirable in other applications so I would assume it is for this format also. The white media surprised me. It is a soft cottony texture unlike all of the others, and in the zoom in shot you can see a plastic mesh they have on the inside of the filter supporting the media.
The regular Fram CH appears to have the same ribbed paper media as the Mopar, and the same pleat count of 60. However, both the Fram TG and XG only have 50 pleats. (The K&N had 48 pleats.)
I don't know what to say about the TG other than it's somewhere in the middle. It has fewer pleats but is yet a different media than any of the others. Build of the plastic frame on the TG is similar to the Fram CH; the XG and the Mopar are all different.
The Mopar is the only filter where the center piece of the filter is fixed solid, in all other filters (all three Frams and K&N) the center piece can spin freely.
#22 ·
Sorry guys, I'm trying, but I just don't get it. Especially with the lower frequency and therefore lower expense of oil changes in the Cherokee, and modern cars in general, I can't fathom why anyone would not use the Mopar filters. I know that "enthusiasts" sometimes like to change things just for the sake of changing them, but to deliberately throw a wild card into their warranty coverage, for a benefit no one can clearly identify, is beyond me.
#23 ·
You can't beat Mopar for warranty purposes :laugh:
I personally find it fascinating how the build can vary so widely on oil filters, and how motor oil can also vary so widely in add packs and blends for the same grade. If you provided oil change records and receipts with the right grade oil and a new filter, I doubt you'd lose a warranty claim for engine failure.
This latest comparison is interesting in how similar the cheapo Fram CH is to the Mopar, how similar the Fram TG is to the K&N, and how unique the Fram Ultra XG is. The XG may be the first unique design that greatly exceeds OE for this application. Mind you, this particular filter design/application was new in 2014 so these new filters are just starting to roll out. K&N was the first aftermarket.
#24 ·
I wonder if other XG filters come with the same white media.
#25 ·
Well this K&N cartridge looks better than any of their canister filters that I've seen the guts of. Most of those flow real good because they don't filter very well. :p They tend to have way less pleats and that means there's no way they flow enough without sacrificing filtration. Either that or it's in bypass all the time.
Still, as pointed out, this cartridge has less pleats than others. Screw that. Just stick with a known good... Mopar, Wix/Napa Gold, Purolator, maybe the higher end FRAMs like the XG.
#29 · (Edited)
While Mopar is owned by FCA it is a separate company and is viewed in the same light as any other aftermarket supplier by FCA. I personally know someone who ran a Mopar CAI and when they had engine issues FCA denied the warranty claim and said it was caused by the CAI. After a long legal battle, this was eventually reversed because neither the dealer or FCA could prove the fault was a direct result of the CAI.
So, in order for there to be a warranty denial, there would need to be proof that the filter was at fault. If there is, the liability immediately falls to that manufacturer and/or the installer.
My main point is: Using Mopar parts doesn't automatically offer more protection when it comes to a warranty claim investigation.
Ad for the filters... I think there are lots of quality ones out there. Fram is a customer of mine so I know their processes very well. I have also worked with Wix. I always find it humorous when I see someone saying on brand is better than another or better yet when one of those brands has a commercial and spins their superioress after seeing them made on the same machine.
There are pictures in this thread that if you inspect closely you will see that there are essentially two filter types. Try not to look at the paper colors as that is just a die or post treatment for aesthetics.
I should add, that things like molding depth, pleat count, and crimp depth are all adjustable on the fly and just because two things are made on the same machine doesn't really make then identical. The rub is what is really better? Doing what I do, I've heard engineers from every company tell me why theirs is better.... They are all really compelling but one of them has to be lying....
#30 ·
Been running the Wix WL10010 on the wife's jeep the last seven changes.
That Fram Ultra XG11665 is supposed to very good as well from what I've read over on BITOG fourm, may look at those when I use the last of the Wix on the shelf.
The Mopar are good, but I know Chrysler also goes buy contract bid on their Mopar replacement parts, at one point some Mopar oil filters (not these specifically, but Ram truck oil filters) were Purolator brand filters, and the Cummins diesel truck filters are actually Fleetguard brand, they just paint them black or grey and slap a Mopar label on them just like Napa Gold filters are typically Wix as someone previously stated.
#32 ·
Actually trying to buy a quality filter is the way to go. We are changing oil generally less than in the past. That just puts more stress on the filter. A filter in these vehicles on the extreme, might actually have to filter properly for 10k or 12 months. That's a lot of contaminants to collect out of the oil and keep functioning properly. Just do not want to skimp on the filter.
For myself the way I look at it, I may now only change every 6 to 8 months when I am at 20-30%. That's working out 2 per year at most vs 3x year past vehicles.
So I am using Pennzoil synthetic (always used conventional in the past) and Mopar filters. Would not have an issue using a different quality brand of filter though.
#34 ·
Bobistheoilguy has lots of threads on filter comparisons. Mopar is made by one (or more) vendors to their spec and is of course fine ... is there something better ? Maybe. In general most filters will not have problems if you change oil on schedule - but the cheapest fram filters generally don’t fare as well in some of these comparison tests. Napa gold, wix, champion labs typically get good reviews - but can vary from application to application.
If engine is still under warranty there can be advantages to go oem in the unlikely event there is an issue ...
#35 ·
Here's the Mobile 1 M1C-456A, rated for 20k miles. It looks strikingly like the Fram TG, and has 50 pleats like the Fram TG and XG. Note the Fram XG is only rated at 15k miles, but I read elsewhere Fram XG filters to a lower micron level (higher efficiency) than the M1.
