Did you really need a TH or will Limited with AD2 work fine next summer? (w/all terrain 17' tires)
Pick up a local off road guide. One where they "rate" the difficulty of a particular trail. Many trails would definitely be doable by a Limited. Some are even doable in 2WD. Others not so much, even for a stock TH. Some trails need heavy modifications to pass the trail.Did you really need a TH or will Limited with AD2 work fine next summer? (w/all terrain 17' tires)
That is my number 1 concern. Floating on rocks is not fun.The a/t tires are most important. Lots of rocks out there.
Not this last trip, other than a little section below the Shafer Trail. The Park Service was reporting some sections that had washed out from a storm two weeks earlier.@taatmk did you do the white rim trail?
