My 2014 built in December 2013 has been perfect to date. No transmission issues. In fact its probably the smoothest shifter I have had. Transmission does get a little funky at times mostly due to the adaptive learn system that is always working and the missing 2nd gear on downshifting. That 2nd gear missing was a software update on the 2014 and early 2015 models to help the durability of the transmission.
* When you move the shifter to the left it will show you what gear you are in at that moment. As you slow down to almost a stop but still moving, move it to the left and see what gear it shows.
If you see 2nd then your trans is the newer updated one. If you see 3rd you have the older hardware transmission. Basically it will stay in 3rd till you stop completely.
On the other hand you could have a 2014 or early 2015 that had the trans replaced with a newer hardware equipped transmission. In that case you will have 2nd gear and it will show when coming to a stop.
I also tow but no where near what @
SkipW does. My 2014 handles it just fine with no issues. Towing does add a lot of stress to the transmission. If there is a lurking problem it will come out with towing I would imagine.
If you have any doubts just do that little test I gave you and then you can rest assured you got the newer transmission. That's assuming that all the recalls had been done.
Also you can not compare a Jeep Cherokee to a Jeep Wrangler for off roading. Two different vehicles. I for one would not like to drive a Wrangler for the next several years in my normal driving. A Wrangler is made for off roading and a Cherokee in made for off roading and everyday driving. Its a compromise to get 100% one or the other. But that's my opinion.
The Cherokee for off roading does very good. There are some good photo albums on this forum to prove that.
And yes its a true Jeep as much as a Wrangler is. It just functions differently for its intended purpose.
