1 - 5 of 5 Posts
2016 Jeep Cherokee Trailhawk - Arctic White
I'm trying to find a good place to get my 2" Hazard Sky Aussie lift installed near Denver and just got a quote of $650-700 for labor alone. Going to check around a few more places but does anyone have a place they recommend? If I keep hearing numbers like that this will definitely be an at-home job.
· Super Moderator
Find a local Jeep club and ask for some assistance. If you find the right group, they'll get you together for a wrenching party and you'll be on your way.
$700 seems steep for compressing springs, putting in spacers, and replacing the springs.
Sent from my SM-G965U using Tapatalk
@gravitywell that was my thoughts exactly on the cost. Got about 4 more quotes that were about the same. Ended up spending the $10 for the Service Manual on ebay and thinking about going after it with a buddy. Only thing I'm unsure on is either dropping the lower control arm or using a spring compressor. Seems like the compressor is the easier route as long as you're careful.
Reactions: gravitywell
· Super Moderator
Both, makes it an easy job.
Compress the spring, lower the arm, and slide the spring right out.
It /can/ be unnerving to be wrestling a compressed spring. ;)
Ended up installing myself with a buddy and dropping the LCAs. Pretty easy after doing my research. Hardest part was getting the bolt back through the LCA and knuckle!
1 - 5 of 5 Posts
