These hooks were discussed several years ago as a reasonable cost upgrade.
A forum member had a very similar set up he could have manufactured and sell to those interested.
For all practical purposes those from Hazard look identical from what I remember from the forum member.
What the story was between the two I have no idea.
I am sure if you spend a little time doing a forum search here on those hooks you will get all the information you want.
I believe there was even install instructions. Its a bit of work and cutting( plastic on the grill)..
From my perspective over the years those were the only reasonable alternative for non Trail Hawk Cherokee tow hooks.
The alternative was a complete change of OEM parts install to get those hooks. Requires changing out other parts. Cost was north of $1,000.
The Hazard set requires replacing the OEM aluminum brackets with steel ones in the kit I believe. From a safety point you will have to determine if that degrades or compliments
the vehicle bumper structure. I have no idea.
I always thought that was the way to go if I wanted hooks on my 2014 Limited with AD2.
Let us know how it comes out.
