Kl squeaking
1 reading
1.5K views 6 replies 4 participants last post by  Skidmark
#1 ·
Hi, can anyone help me with the problem of squeaking around the door when driving at higher speeds? (80km/h and more). I checked the sunroof, rear seats,front hood and door interior panel and found nothing wrong. Cherokee 2016 2.2
#3 ·
Huh I'm wondering if it's your driver's seat and its position. Can you try 80km/h and adjusting your seat to see if the sound changes? I think I get this in mine but I tend to ignore the squeaks and rattles.
#6 ·
When I drive off road, the unibody twists enough so the driver door seals squeak.
Put Petroleum Jelly on a soft cloth and wipe it on the rubber seal and the car body.
Just a very thin film. Wipes off the dust and allows the rubber seal to slide against the unibody silently.
Silicone spray lubricant would probably work. You might be able to buy something else locally that works.
Works good on the liftgate so the liftgate doesn't get stuck closed.
Put some on the fuel cap cover rubber seal so it doesn't get frozen closed in the Winter.
