Located in Monson, Massachusetts
Jeep : Cherokee XJ 1992 JEEP CHEROKEE XJ 4.0 35'S LIFTED OFFROAD LOCKED 4X4
CLICK HERE TO VIEW THE PRICE
CLICK HERE FOR MORE PICTURES
1992 jeep cherokee xj.* MOTOR.* 4.0HO* 150k * turbo city cold air intake.* BODY* Bushwacker cutout flares.* c4X4 rockrails.* PMW lower door armor.* FarmerMatt Steel taillights with full LED's* Hood vents.* front custom Hanson winch bumper with a Warn x8000i with AMsteel line and billiet fairlead, and HELLA1000's* with D-rings.* rear bumper is a Tomken with tire carrier and a hi-lift holder,* and a hitch mounted shackle.* inside in very very clean, no rips or stains.* custom camo headliner.* Alpine CD and speakers.* onboard CO2 tank.* power lock and windows.* AXLES* front is a hi-pinion dana30, is has been ALL rebuilt* new dana spicer 4.56's* all bearings and seals* full traction disco's.* Alloy outer axle seals.* Poison spyder rock ring.* Currie weld on control arm skids.* 760x u-joints.* cut down lower control arm mount for better axle droop.* REAR..* the rear is a 8.25 with 27 spline Yukon alloy shafts.* full Detroit locker with 4.56's.* raised shock mounts.* zj disc brake covn. with all new brakes and lines.* both axles come with spares.* LIFT* front lift is...* RE 4.5"zj coils with ACOS that net about 6.75"* front shocks are bilstien 5150 in the 10" travel.* TnT Y-link longarms.* RE HD trackbar and HD frame mount.* REAR.* the rear lift is RE 4.5"packs with a 1"block and Tera 1.5" shackles.* rear shocks are Rancho 5000's. WHEELS AND TIRES.* wheels are steel rockcrawlers* they are 15x8 with a 4"BS.* tire are 35x12.5x15 Baja Claws that are near new!* also has a full size spare....(pluged!)* STEERING* the steering is Currie HD with a driver side over the knuckle.* new steering box and shaft/* zj pitman arm.* this steers just as good a as a car!* this jeep has been very very well takin care of, oil changed EVERY 2500 miles.* i have over 15k into this jeep, i really don't think you can build one for this asking price.*
IF YOU ARE INTERESTED IN THIS PRODUCT, CLICK HERE TO BID OR TO BUY IT NOW
