1 - 8 of 8 Posts
Can any body tell me where I can find a diagram of interior fuse box numbering. It took me a while to find the interior fuse box which is located on the drivers side below the head light switch and behind the storage compartment door. The fuse slots are not numbered. I am looking for the fog light lamp fuses #F91 -7.5amp- left light and #F92-7.5amp-right light. Any help would be greatly appreciated:smile:.
Sent from my XT1585 using Tapatalk
But it’s totally different from my Jeep cherokee kl 2015 interior feus box
Its diesel limited model
Australian order
I would like to add a Bussmann ATR Add-A-Circuit but can't figure out how to remove and replace
the fuse without dropping and loosing it.
How do you replace the fuse?
Do you actually put your hand through the opening to get to the fuse?
My hand won't fit.
Should I use the fuse puller in the Power Distribution Center or is there something more useful?
I bought some really long needle nose pliers that might work if I am desperate.
I can foresee dropping tools and fuses down in there never to be seen again.
My hand won't fit.
If you're in the interior fuse box whatever you drop will just end up on the floorboard carpet. There's not the normal deep, dark nothingness to lose it in.
Sent from my SM-G950U using Tapatalk
1 - 8 of 8 Posts
