Hi @buccboy1 , Just a reminder, those measurements in the diagrams in @Mark_ 's post are in inch-pounds. (the upper numbers) The foot-lb numbers are very low in the range so unless you have a very good quality torque wrench, use the inch-lbs. There are many a story of cracked plastic on the upper and lower intakes due to accidently using foot-pounds... :-(Hi new to the forum this probably be ask before. I'm changing out leaking oil cooler assembly and doing plugs also. I can't find the torque specs and the tightening pattern for the intakes. Anyone know. Thanks
