Heater Cold on Driver side, Normal on passenger side and floor/defrost vents
1 reading
12K views 4 replies 3 participants last post by  Doug Brown
#1 ·
2015 Cherokee heater works normal when using the floor vents or the defroster vents. When switched to the dash vents the drivers side blows cold air and the passenger side blows hot. Anyone else have this issue? Any ideas on a cure?
#4 ·
actually i had the same issue. the problem was in faulty temperature sensor. There are 5 or 6 in our system. when you turn all air to dash vents - the sensor assumes its 100 degrees all the time, and thats why the cold air blows. replaced teh sensor and all is good now
