Here's the first few things that I did to Hawk since I purchased it in November.
Thanks to others on this Forum and their documentation, I successfully installed my Blue Ox baseplates without any issues. I won't re-document this since it's already addressed well.
I also recently ordered from Amazon:
Roof cross bars from Rage Powersports
Draw-Tite 59404 Roof Rack
So, I started out mounting the cross rails and marked them down to cut them so they didn't hang over the vehicle edges. Cutting was simple and I just placed a pilot hole to drop the screw in for the end caps.
I then took the rack and did a pre-mount test fit. I did take the roof rack and put 4 coats of bedliner on it. Once it was dried, I mounted the rack face plate.
Here's a couple of thoughts:
1) the rubber seals that go over the two rack pieces is very nice to have but a bear to get out of the way when you are putting the set screws in place. I figured out that if roll them up it can be done.
2) careful putting the screws in place on the plastic face plate. Those can be overtightened and snap it. I used a low setting on my drill to ensure I didn't crack it.
Mounting went just fine and lined up nicely. No issues with opening my sunroof (see picture).
Again, thank you to others for their write ups that helped make my effort easier.
I drove around the block and noticed noise with the sunroof wide open but much less when the sunroof was tilted up. I suspect that there would be noise but hey, it's a brick on top and should expect that.
Hopefully some of these pictures and information can assist others. Next up, my RRO Steprails that should be here in about 3 weeks. I will try and update this thread with that install as well since it will be a self install.
