Thanks for the reply. My concern is that if I put Roofnest Falcon 2 RTT on the factory rails with crossbars would it be able to support the weight.
Hi
@Harsimran Cour , aah, I understand. Sorry for the misunderstanding.
Sooo.... I would think almost definitely the 150lbs is a
DYNAMIC LOAD. For example, if I had three pieces of luggage that each weighed the general airline-maximum of 50 lbs each and put it on my roof. I probably would not want much more when I consider I need to strap that down to not fly off/affect car handling while going 75mph on an Interstate in a crosswind.
However as for a
STATIC LOAD (when the car is at rest), the Cherokee's frame of course is strong... the roof rails are mounted directly to the steel of the car and the roof (and its pillar supports) are designed to support the car weight in the event of a roll-over and not collapse so I would think the car, car frame/pillars/roof rails could easily support far more than 150lbs. 150 lbs is the weight of, say, an average-sized person. If I stood on the roof of my car over one of the four roof rail mounting points (with the car at rest of course [static]), I would feel comfortable with 3-4 people on EACH of the four mounting points and the car pillar supporting it without a problem.
In fact, I went to the Roofnest website they also mention there:
"Remember, roof racks are rated for DYNAMIC loads (e.g., when you’re going 100 mph and slam on the brakes) – the load that the vehicle and rack can carry when you’re parked is a STATIC load an can be as much as 7x the dynamic rating. Any well-installed rack which is rated for the load of the Roofnest by itself will have no problem supporting you and others in the tent when your vehicle is parked."
So, I can't imaging you'd have any issue weight/load wise (and especially on a vehicle like the Cherokee which is especially stressed for off-road use).
pss: The above is just regarding the
Cherokee roof strength and
factory rails. Now, if you add aftermarket cross rails (e.g. Rhinos), you'd need to make sure they're rated for not only the load [across the crossmember] but also that the clamps that hold them to the Cherokee roof rails are strong enough to hold the collapsed RTT while driving. I don't go camping so my crossrails are Amazon Basics. Definitely not what I'd put under a RTT! LoL!!! 😱
