The difference I see in the set up is, on a multi mount like I have, there are two supporting bars welded in the center that end up dividing the mounting area into 3 segments, 4 light mounting supports. If you were to put a light bar on that the two bars would interfere cussing the light to be moved far forward of the rack to clear.
look at the 4 runner stealth with light bar setup on their site.
Mine was ordered for multi series e 10” from Rigid, but I settled on the 360 series spots up front. I had to modify the mount location of the out board lights because the center mounting hole pulled them toward the center too much.
Just figure what lighting you want up there before you order and you should be good to go.
Gobi will do anything you want, even prewire the rack, but where’s the fun in that. If wiring through the tubes, do it before mounting to roof….so much less stress and cursing
