Page 536 of the owners manual contains the following:
"Towing Tips
Before setting out on a trip, practice turning, stopping,
and backing the trailer in an area located away from
heavy traffic.
Automatic Transmission — If Equipped
The DRIVE range can be selected when towing. The
transmission controls include a drive strategy to avoid
frequent shifting when towing. However, if frequent shifting
does occur while in DRIVE, use the Electronic Range
Select (ERS) shift control to select a lower gear range.
NOTE: Using a lower gear range while operating the
vehicle under heavy operating conditions will improve
performance and extend transmission life by reducing
excessive shifting and heat build up. This action will also
provide better engine braking."
My question is, what to you think a good gear range is for towing? I am guessing the weight of the load being towed and condtions would influence but do you think there is a general rule of thumb? (see page 429 and 430 for Electronic Range Select (ERS) Operation)
"Towing Tips
heavy traffic.
