1 - 8 of 8 Posts
Hello all
I’m adding some marker lights and trying to find a spot in the engine bay fuse box that is only hot when the car is on. Couldn’t find it in here. Any ideas of what spot I should use the fuse tap in?
I used F65 with a Buss Add-a-tap.
Refer to the schematic in this post: Headlight Options Post #4.
This is for a 2014 V6 Trailhawk.
There is actually a tiny hole in the fuse where you can stick a pin and check for a voltage.
Also check F66, F85 and F88.
My guess is you have a 2019 or later?
Put a fuse in an unused spot and see if an Add-a-tap works?
I've used those but you'll still have to "ground" whatever it is you are powering, right?
1 - 8 of 8 Posts
