1 - 7 of 7 Posts
I have a 2015 Cherokee Limited and am installing a Rove R3 dash cam. It needs two fuse connections 10 amps or greater for each circuit. Are there two such fuses in the interior panel? Checking them it seems they are all always on instead of ignition on, but I suspect it could be because a door is open, key fob close by, etc.
Welcome :)
And also one thing to keep in mind : when you wire a dash cam on Live power (for Parking mode or whatever they call it), remember it will drain your battery. Battery in the Cherokee is known for having a short life, for a few reasons. You should consider charging the battery at home, at least once a week, overnight.
Welcome :)
And install a quality premium "dual purpose" AGM battery. They're going to need it...😎
while it might not be handy
always on = in armrest 12v outlet
accessory= 12v outlet below radio.
Note, I don't think the armrest outlet is always on, no? Isn't it ACC (Ignition)? I think only the cargo bay outlet with the fuse (F92) that can be switched between ACC and BATT is the only outlet that can connect to battery power.
If the outlet cover has a key, it is powered when ACC or ON. If the outlet cover has a battery symbol (like in the center console), it is powered all of the time. The exception is the rear outlet. The cover shows a key but you can swap F91 to F81 to power all of the time. I think 2014-2018 shows the rear power with a battery, but fuse swap is the same.
Front = acc only
Armrest = always on.
rear = can be either with fuse.
(this came up not long ago)
1 - 7 of 7 Posts
