1 - 13 of 13 Posts
Hi All,
Does anyone know how to remove the front bumper? Specifically the Black fascia that houses the fog lights/active grille shutters?
Noticed I have a blemish on mine (not sure what the heck its from, Jeep only has 275 miles on it)...
I got under the Jeep and I only saw a few hex bolts holding the rear part of the fascia to the protective cover (where you change the oil filter) Otherwise, Im stumped and I don't want to go putting more gouges in the black plastic. :(
If ANYONE can help out! Please let me know! It is GREATLY appreciated!
The area in Salmon (no idea why its not red) is what Im referring too...
Jonathan
Reactions: Sen66
THANK YOU!! THANK YOU!! I went on the website in the PDF you sent and they have the removal instructions for the Latitudes & Limited's! Its EXACTLY what I was looking for!
THANK YOU AGAIN SO MUCH! :)
I don't know where you looked on the website, but I need the same instructions.
Could you provide a link to the exact page you found the instructions on?
I have a Sport, I assume they are close to the Latitude / North, at least with regards to fascia removal.
Cheers
Cheers
I don't think the Sport can get AD2, thus can't be flat towed...so there isn't a specific manual for the Sport model. The LTD/LAT removal process looks close to identical to the TH, so I assume the Sport would be no different.
LTD/LAT Fascia Removal
Here is the Vehicle Selector page
Hi All,
Jonathan
Wow, seems like if ya hafta go to step 7 you just oughta live with the blemishes??? :|
Wolfdog
It's the same. I had a look last night. The plastic connectors are pretty easy to remove after I figured it out and ripped a couple of fingernails off in the process. The annoying bit is the plastic rivets holding the bottom on in front of each wheel. Gotta drill them out and have four new rivets ready to re-install the fascia. What's wrong with screws? hmmm? Hmmmm?
Use a small flathead or 2 to remove the clips, super easy. You don't have to replace the rivets as they do very little, and there should only be 2...at least on the TH.
1 - 13 of 13 Posts
