Trying to install aftermarket driving lights.
Made a bracket that is attached by the front tow hook bolt.
Used a barn door bracket for the light bracket.
Cut off one end of bracket.
Pictures attached. This is a work in progress so beneficial comments are encouraged.
The Hella 500FF lights are in front of the bumper which is not good.
Will put a trailer connector on the wires so I can remove the light housings when off road and in parking lots.
This is not the solution I want but it is what I have figured out so far.
Will hook up a remote switch to turn the lights on and off.
The lights should only activate when the high beams are on but I do not know how to do this.
There is 6 ohms of resistance between the bracket and the battery negative terminal so I should run the light ground wire directly to the battery.
