Dirty Front Collision/Adaptive/Parking Sensor Error
10K views 7 replies 6 participants last post by  JeepCares
Thanks for the reply, however that does not appear to be the case. I get this error both when acc is on and when it is off. I also get at the same time a yellow error light on the dash which in the manual is titled : "Forward Collision Warning Off Indicator Light" in addition to the image that appears on the info display between the gauges. The image that displays clearly shows the the bulb sensor when it disables itself.
Whatever the issue is the dealer most likely will have to solve it. That is unless you have a lot of dirt, bugs, and/or mud on your roads.
My 2014 has the same set up and I do not think Mine has shut down 3 or 4 times in 5 years.
It always reset after being cleaned or the bugs falling off.
I find that is pretty tolerant of dirt ect.
Could be a failing sensor ect.
Good luck and let us know the solution.
