1 - 20 of 97 Posts
If anyone has had the tow package and wiring installed on a 2019 limited after purchase do you mind sharing how much you paid?
I need to add the tow package and would much rather have the dealer do it since my car is a lease and from what I am reading the wiring is very complicated.
Thanks.
Sent from my SM-N950U using Tapatalk
Reading the forums it seems to be around $700. The have to update the computer to enable the tow wiring. Parts seem to be $300-400 depending on where you buy
Wiring
Hitch
Bumper plate if you need it
· Premium Member
Thanks.
Keep in mind that neither the dealer nor anyone else has the capability to install the "tow package," meaning the tow group offered as a factory option that provides a 4,500 lb (4,000 with the turbo) towing capacity. There are hundreds of postings about this on the forum. The dealer can install ONLY the tow hitch replacement bumper and the tow wiring harness, which will give you a 2,000 lb. towing capacity. (If they know what they are doing it should LOOK like the factory tow group when they're done.)
Reactions: RustBucket
Wiring
Hitch
Thanks.
For parts alone I was quoted approx. $ 500.
Waiting on service to call me back with the install quote.
· Super Moderator
The 2019s are an exception. To the best of my research ALL 2019s come prepped now and all the dealer has to do is install the harness and hitch to get the 4500lbs for 3.2l, 4000 for the turbo and 2000lbs for the 2.4l.
Reactions: Jeepster1
OK I just went to the Jeep Website and its still giving the 4,500 (when properly equipped) / 2,000 lb limits and still lists the Towing package as.
OPTION GROUPS
Trailer-Tow Group
  • 7- and 4-Pin Wiring Harness
  • Auxiliary Transmission Oil Cooler
  • The auxiliary transmission oil cooler maintains the transmission at the optimal temperature for it to operate.
  • Class III Receiver-Hitch
  • Full Size Spare Tire
  • Trailer-Tow Wiring Harness
  • 3.517 Final Drive Ratio (Unavailable with some configurations)
  • Heavy-Duty Engine Cooling (Unavailable with some configurations)
The heavy-duty engine cooling system is designed to vent excess heat generated by heavy engine use.
I also don't see the Tow Prep option.
· Super Moderator
OPTION GROUPS
Trailer-Tow Group
What the website says if often wrong. Every single Cherokee sold in Australia is prepped. It’s not too far fetched to think ours are now too.
· Premium Member
So basically you're guessing? That's "the best of your research"?
Discussion Starter · #9 ·
Received 1 quote for the install at $ 149.95 per hour for labor - and they estimate 3.5 hours. That's almost $ 600 for the install.
Am I wrong in thinking that $ 149.95 / hr for labor is insane? I don't think I paid that with my Lexus. I know I am in NYC and prices tend to be higher but wow.
· Super Moderator
No, my guess is that they all have been prepped, yes. Because based on my research of asking sales people and going on lots the kit can be added easily and provide the full capability.
We have members on this forum with 2019s who’ve had the hitch added by the dealer and FCA gave them the full towing capability. Just because that goes against previous experience does not make it wrong. It may just mean FCA changed something and they all can now tow what they are advertised to tow.
Reactions: Fj4080
So are you saying that all 2019's come with the auxiliary transmission cooler?
What's the point of the GTW column with different rows for the Trailer Tow Package in the owner's manual if the only difference is a hitch? How else would a trailer be towed?
What TSB or other evidence is there out there that says all Cherokees can haul the maximum GTW?
Perhaps you are right. It took a while to figure out the Flat Tow Wiring Kit wasn't needed in the 2019's, including several owner's manual revisions. However, need something to back it up. For example, what Google search did you use to find evidence? I'm striking out.
Discussion Starter · #12 ·
Wait? So the wiring kit / harness is NOT needed for a limited 2019?
· Super Moderator
I have our experience here on this forum with other 2019 owners. We’ve had I believe two or three people who’ve gone to the dealer to have it installed and it was added to their vehicle sheet. They called customer service to be told they got the full tow capacity.
I didn’t say it made sense and it does go against our previous experience but if FCA says it’s okay, then it’s okay. To the best of my knowledge we haven’t had a 2019 owner go to the dealer and be told otherwise. For North American market 2014-2018 no, you can’t just add it. However, based on the user reports from a few 2019 owners for some reason they’ve been prepped.
· Super Moderator
Yes, it is. If it has actually been prepped then all they need is the wiring and hitch and the flash from the dealer and they can be sent happily on their way. However, if they aren’t prepped then they’ll be limited to 2000lbs. But we don’t have reports from owners saying they got stuck at 2000lbs yet.
Len, I think he means the flat tow harness. Flat tow harness is no longer needed with 2019s. That's the FCA official word, we have no details on what the improvement is, to prevent a death wobble condition.
Guys, the towing thing is ridiculous. One example : from 2017+ (or is it 2018+ ?), all AD2s and THs are considered *prepped*, requiring only a dealer added hitch and wire harness, for 4500 lbs (V6). Is this still true for 2019 ? AD2s/THs only ? All AWDs ? The confusion surrounding all this is surreal... and FCA are of no help in clearing it up, in print...
· Super Moderator
Thanks I thought they meant towing behind, not front. Again, thanks.
No worries, that was an isolated reaction to one comment about the flat tow harness.
About the prepping thing... It can't be for all AWDs, because the full size spare is a requirement for high towing capacity, and only AD2 and THs get them by default. And 3.517 final gearing is also required, in North America (V6), for max towing capacity, so again only default on AD2s and THs.
2022 Trailhawk 3.2L
My 2016 V6 without tow has the auxiliary trans cooler. So says my build sheet anyway.
· Premium Member
Actually the official limit is 4500 lbs. without the Tow Group. Many later Cherokees though do have aux transmission coolers installed OEM which are a key element of that limit. As the years from 2014 progressed it seems that more had the aux cooler OEM. All Trail Hawks from day one had it. If you had AD2 you had it from day one. Also it seemed that more may have had it as the years progressed simply because the ZF needed it because of its compact size and heavy workload (4WD) from the Cherokee. Simply a precaution by FCA in my opinion.
This has been discussed many times over the almost 5 years I have been reading this forum. @Fj4080 kind of confirms Aux cooler in this continuing saga.
I can remember the old days that many times the tow shops would have to add an aux cooler and possibly change the axle ratio at the same time. This was all depending on how much weight was involved. Those were the main changes needed to tow. Sometimes adding some simple suspension changes like HD shocks were also done.
I would have a shop add a hitch, tap into the rear lights, and change the fluid every year at the end of the tow season. At my tow weight an aux cooler was not needed.
That tow weight was under 2k. The old days are not much different than today in the reality of things except the tail lights.
The Cherokee itself, structurally OEM, will tow 4500lbs as it sits. I have seen nothing to the contrary. Its the extra cooling that is the issue.
Aux trans coolers can be added if needed, specifically for the Cherokee. These are aftermarket systems for the Cherokee. That is the most important element of the Tow group outside the hitch/wiring cable. The extra engine cooling may simply be the extra fan on the radiator if so equipped.
The axle ratio is what really limits the Cherokee towards that upper limit if its non OEM tow. The main thrust is to keep the parts and equipment cool, primarily the transmission. It always has been and always will.
Now obviously there is a warranty involved so that limit is there for a good reason. FCA will guarantee your tow up to that limit with their specific equipment package. Aftermarket packages do not pass the muster as FCA can not nor should they guarantee their performance or how thy will stand up to various weight limits.
Also another issue is non OEM tow receivers and wiring set ups. If not installed properly they can actually damage the vehicle itself.
A properly installed aftermarket tow set up is obviously at your own risk if you are towing 3,000lbs or so but I doubt there will be issues if the vehicle is maintained properly. In the end its proper cooling...…
One of the reasons I have gotten OEM tow set ups on my last 4 Jeeps was its a well integrated package with the axle ratio so as to maintain that warranty and on my 2014 a Max Care Life plan. That OEM tow was the reason 3 out of the 4 Jeeps had to be factory ordered.
But just some general observations.
Reactions: Fj4080
After reading this thread I am glad I get all my vehicles with the TOW package already on there. And you can't believe what they tell you at the service department as I had an employee last week at the service department tell me that FCA no longer recommends the KL for being towed behind your vehicle. And I wasn't even interested in getting false information like that as I will never being towing mine.
1 - 20 of 97 Posts
